Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › AEG Washer Lavamat 72600
- This topic has 9 replies, 4 voices, and was last updated 18 years, 6 months ago by
johnnyhoz.
September 17, 2007 at 4:02 pm #30611
johnnyhoz
ParticipantWent to this machine today, when any program is selected and the start button pressed it locks the door pumps runs for 15seconds then it stops it takes no water and times down on the display. No power to water valve cables go directly to lower board, checked pressure switch appears to be OK.
Think it’s the board but has anyone come across this before, board very expensive can it be repaired ?John & Stephen
September 17, 2007 at 6:32 pm #227815dna
ParticipantRe: AEG Washer Lavamat 72600
Havce had heater faulty b4 check heater. Mega the heater after its been on through dianostics. it may also give you fault code in diagnostics
September 17, 2007 at 6:45 pm #227816AMS
Sounds like you’ve got an inadvertently activated demo mode – possibly! It is selected by holding the PREWASH and SOAK buttons at the same time while switching the machine on at the rotary dial and moving it to DELICATE SPIN. Buttons need to be held for more than 4 seconds. It is deactivated by doing the same procedure again. It happened to me once, and was pulling my hair out until I discovered this gem. Hope this helps.
September 17, 2007 at 7:01 pm #227817johnnyhoz
Have you a copy of the diagnostics Please dna
and thanks for that Dave I’ll give a goJohn
September 18, 2007 at 5:52 pm #227818johnnyhoz
Does anyone have the service manual or diagnostic info on this washer?
John
September 19, 2007 at 11:23 am #227819johnnyhoz
September 19, 2007 at 6:15 pm #227820Penguin45
Mail, John.
September 19, 2007 at 6:43 pm #227821johnnyhoz
Thanks Chris much apreciated
John
September 25, 2007 at 4:39 pm #227822AMS
Any feedback on this one John?
September 25, 2007 at 7:50 pm #227823johnnyhoz
The diagnostic seamed to go ok until I got to the water check, there was obviously no water flow and no power to the water valve but the led that should acompany this fault did not illuminate, customer is buying a replacement so I may get the AEG to test further
John
