AEG Washer pnc91400209601 model 72630
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries AEG Washer pnc91400209601 model 72630
  • #55275
    senseib
    Programmed this m/c up for 80mins 40 degrees wash. At 68 mins the m/c just stops and will not progress any further, except every now and again it will suddenly burst into spin and tumble or a few second then it stops again. Checked heater ok and motor seems fine whilst on spin. Never come across this fault before on an AEG.
    Can anyone help?
    Brian.
    #322771
    Seamy
    Re: AEG Washer pnc91400209601 model 72630
    Have had problems with AEG motors cutting out on thermal o/l on long programmes. Sounds like tacho problem that you describe though. Check wiring & plug connections to motor & board as they suffer from duff connections every now & again. Have you checked brushes & armature?
