Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › AEG Washing Machine
- This topic has 12 replies, 6 voices, and was last updated 13 years, 6 months ago by
mjhservices.
October 9, 2012 at 3:21 pm #71873
mjhservices
ParticipantAEG Washing Machine
No motor action. Run through test cycle and the light flashes orange 5 times and red twice?
Any one have these fault codes?October 9, 2012 at 3:39 pm #382635Martin
ParticipantRe: AEG Washing Machine
Two problems: –
Wrong forum ( should be trade tech)
Model number? 😕
October 9, 2012 at 4:14 pm #382636iadom
ModeratorRe: AEG Washing Machine
Moved. 😉
October 9, 2012 at 4:42 pm #382637mjhservices
Sorry I forgot. The model number is L52840 914903417/00
October 9, 2012 at 4:43 pm #382638Hollytree_Technical
Sounds like it is showing an E52 error which is “No signal from the tacho”, I assume that you have checked the carbon brushes?
Jem
October 9, 2012 at 5:15 pm #382639mjhservices
Yes brushes ok. Its only 14 months old and used 2 or 3 times a week.
October 10, 2012 at 2:04 pm #382640leavemetogetonwithit
If it is E52 it’s a common enough problem and can be a right b”*!:;r to diagnose accurately.
The following thread may help to give some pointers – or it could just complicate it for you. Probably best just to read the posts from repman and captaincaveman1 within it.
trade-technical/diagnostics-programme-aeg-lavw1250-t73016.html?hilit=E52#p357193
Mike.October 10, 2012 at 4:05 pm #382641mjhservices
Thanks Mike
But do you know what 5 Orange & 2 Red lights flashing means?
MarkOctober 10, 2012 at 5:33 pm #382642leavemetogetonwithit
Well that’s how the more modern Lux ones signal a fault code although I don’t remember whether that = 52 or 25. But E52 is a common fault code whilst I’ve never heard of anyone seeing a E25.
If you’ve got an account with Connect you will normally find all the manuals and diagnostic details on their “mediator.” If not, pm me your email address and I’ll see if I can send them to you.
Mike.October 10, 2012 at 5:46 pm #382643mjhservices
Thanks Mike
I do have a Connections account but how do you get into mediator?October 10, 2012 at 5:59 pm #382644leavemetogetonwithit
Home page, left hand menu, washing machine, AEG, choose or type in model and that should get you in. With model be aware you can get LAV*** etc. or just L*** with some others.
Mike.October 10, 2012 at 7:00 pm #382645mjhservices
Thanks Mike
October 11, 2012 at 8:11 am #382646Seamy
Check the usual, motor brushes, wiring to motor & plug connections on p.c.b , tacho, etc.
