AEG Washing Machine L64810 (91452415000)
Start on any programme and it starts to fill for around 10 seconds or so and then pauses for 1-2 seconds before the pump pumps out the water and the door light comes on. Spin & drain programme ok. No fault code is displayed.
Check every part from valves to NTC & motor etc, all ok
ANYONE HAVE AN IDEA?
Might be best you enter diagnostics mode then go to the 10th position to find the last alarm/error code in its memory? Could save a lot of guessing I would think?:D
MOTOR has to be a major caution as well as heater insulation etc etc….Of course.:wink:
