AEG washing machine not taking in water
Home Forums Public Support Forums Help And Support Washing Machine Help Forum AEG washing machine not taking in water
  • #90287
    Sheelzer
    AEG LAVAMAT 74640 which is now 13 years old but has given very few problems – stopped one minute from the end of a cycle and didn’t go to zero. I manually switched it off and took washing out. Put the next load in but when I program it and switch it on it sounds for a few seconds as if it’s starting and taking in water then immediately stops and doesn’t do anything else. No error code shows. PNC is 91400240700
    #444285
    Jackcox1
    Re: AEG washing machine not taking in water
    Check pressure chamber for blockages, pressure switch and inlet valve.
