AEG washing machine not working.
Home Forums Public Support Forums Help And Support Washing Machine Help Forum AEG washing machine not working.
  • #76118
    Basz
    I have an AEG Oko Lavamat 74640 Update and when it is switched on the pump runs for a few seconds and then nothing happens. The start/pause light flashes. no fault code shows. I have opened/cleaned filter but made no difference. Any help would be greatly appreciated.
    #397316
    Re: AEG washing machine not working.
    An error code is shown by a sequence of flashing LED’s . The ‘End of cycle LED’ and the ‘Start/pause LED’. Count the flashes of the former for the first digit of the error code and the latter for the second. There is a longer pause between flashes before the sequence repeats itself. (e g first LED 3 flashes, 2nd LED 4 flashes = error code 34) 😀
    #397317
    Basz
    Thanks for the response. I have checked again and the “end” of wash light does not light up at all – just the “start/pause” light flashes continuously. The other lights on are “main wash, rinse and spin”lights at the same time as the start/pause light. Any thoughts?
    #397318
    QUICK FIX
    brushes
    #397319
    shaysmum
    Snap!, i have exactly the same problem, the start light flashing, but no error code.
    Called Aeg they reckon the main board has gone…..
    Did the op manage to get this sorted?!
    Any other thoughts?
    Thanks for any advice.
    #397320
    shaysmum
    Also going off subject on the “search for an engineer” what does the star mean as opposed to the repair symbol only? thanks!
