AEG washing machine stops after 20 intermitantly code ‘E84’
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries AEG washing machine stops after 20 intermitantly code ‘E84’
  • #36181
    boselecta
    AEG LAVAMAT 72630
    I have the fault codes for the EWM1000 range but this AEG shows ‘E84’ in the memory, this is not a code i have seen before.
    I tested the appliance and all was ok, she now has called me back and says it is still stopping mid-cycle.
    anyone know what this code is?
    #249924
    DentedPorsche
    Re: AEG washing machine stops after 20 intermitantly code ‘E
    Hiya,
    Code is in the UKWhitegoods Fault code guide, well worth the money too. 😀
    E84. “Sensing” circuit on circulation pump triac faulty (input signal to processor always 0v or 5v). PCB, Drain, cycle blocked (door open) OFF/Reset.
    HTH
    Brian
    #249925
    boselecta
    Thanks ‘dentedporshe’ found a blockage in circ pump. Think I will have to buy the UKWhitegoods Fault code guide then.
