Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › aeg washing machine zanusie in a skirt ??
- This topic has 5 replies, 5 voices, and was last updated 17 years, 10 months ago by
dal.
June 4, 2008 at 4:41 pm #37183
dal
Participantmodel L IO AEG 50 OVITYPE P64 96 63 S NO 249 OOOO76 BUT INSIDE ITS A ZANUSI ? washes rinses spins but pump is on allthe time smells a bit the board i think its the board????? help dal
June 5, 2008 at 7:53 am #253796Phidom
ParticipantRe: aeg washing machine zanusie in a skirt ??
The last modern Zanussi I investigated only has a device similar to a triac to power the pump, there’s no relay. If you trace the wiring from pump to board you will find which device it is and you can check if it’s short circuited.
June 10, 2008 at 10:41 am #253797electrofix
ModeratorRe: aeg washing machine zanusie in a skirt ??
Phidom is correct most modern machines use small triacs to power pumps, door locks and valves etc with the current on these components being very low they do not a heat sink and look no more than a black blob on the pcb. they can either be on three legs with a blob on the end or more common these days is to surface mount them directly to the board.
these are easily available for main electronic suppliers or pinch one from an old board thet you have lying around
hope this helps
June 10, 2008 at 8:04 pm #253798admin
KeymasterRe: aeg washing machine zanusie in a skirt ??
dal wrote:model L IO AEG 50 OVITYPE P64 96 63 S NO 249 OOOO76 BUT INSIDE ITS A ZANUSI ? washes rinses spins but pump is on allthe time smells a bit the board i think its the board????? help dal
It shouldn’t arise one fault signal for that?
June 10, 2008 at 8:18 pm #253799Phidom
electrofix wrote: they can either be on three legs with a blob on the end or more common these days is to surface mount them directly to the board.
hope this helps
Are you able to renew the surface mount ones without any special equipment? I’ve never tried that but I should think you need a very steady hand with the iron and some decent tweezers!
June 10, 2008 at 8:27 pm #253800Penguin45
If you can solder the start switch back onto a WMA front board, you can do surface mount stuff!
