AEG WD foot problems
  • #99084
    pmb
    Hi I have a AEG L61271WDBI 91460604101 with a loose foot. The nut it screws into has sheared off of the cabinet, there is a replacement part 140000287015 but does anyone know how it fixes into place on the cabinet?
    Thanks, Darren
    #474938
    did some digging, prob as you did and came up with a complete blank
    I can see its a superceded part but give no idea how to fit
    pmb
    Thanks for checking Dave
    I’ll probably just order it, it might be obvious or have instructions
    #474940
    Hollytree_Technical
    It looks to me like it is a “rivet nut”, if you don’t have the proper tool then if you have a hex shaped hole then you may be able to use a bolt to rivet it in place otherwise if you may be able to improvise with a long bolt and a nut.
    Jem
    #474941
    pmb
    Thanks Jem I’ll give that a try
