AEGL84749 – technician report
Home Forums Public Support Forums Help And Support Washing Machine Help Forum AEGL84749 – technician report
  • #38158
    kfiske
    Those of a stout constitution will remember that this machine is hanging halfway through on the fill element of each rinse cycle. I have so far replaced the 3-way inlet valve, the analogic sensor and the 2-level water sensor to no avail.
    Today a technician from Swift Appliance Services visited and said the only suggestion he could make was to plumb it to fill from the main, rather than the tank we currently use. He suspects it’s taking too long to fill on rinse and the mainboard logic is calling time.
    There is something like a 15ft head of water and a *good* flow from the tank, but the suggestion is to rig up a temporary supply from the water main and see if that resolves the hanging. I’ll do it at the weekend.
    In the meantime does anyone have experience of *modern* electronically controlled machines not liking to be fed from a tank in the loft?
    If the change of supply fails to work, my technician pal says it’s a change of mainboard. How much is that going to be, please?
    TIA.
    KevinF. 😥
    #257910
    Re: AEGL84749 – technician report
    kfiske wrote:In the meantime does anyone have experience of *modern* electronically controlled machines not liking to be fed from a tank in the loft?
    Yes, happens a fair bit.
    kfiske wrote:If the change of supply fails to work, my technician pal says it’s a change of mainboard. How much is that going to be, please?
    Lots I expect. 🙁
    kfiske
    Fixed up a temporary mains feed at lunchtime today and set the machine running. At last, it works with no hanging on rinse. Seems the chappie from Swift was correct: the AEG doesn’t like being fed from a tank in the loft.
    The article here explains the matter in some detail – and also gives some brand-specific information:
    http://www.whitegoodshelp.co.uk/wordpre … -machines/
    Thanks to all on this site that have shown interest in the problem and offered help.
    KevinF.
