AFA250 error lights ?
Home Forums Public Support Forums Help And Support Dishwasher Help Forum AFA250 error lights ?
  • #46238
    Kev64
    My AFA250 is intermittently ending the cycle with a constant flashing LED in position 2 (from the left) – the dishes appear to be washed and dry, and it doesn’t do it all the time – it usually completes the cycle ok.
    Could someone please shed some light on what this error code might mean ?
    Thanks !
    #288655
    Re: AFA250 error lights ?
    It’s an odd one. The code specifically points at the inlet valve; however, the tech info suggests a flow meter failure. Your machine hasn’t got one…… Otherwise, you need to check the condition of the rotors (tip blockages). The safety cut-out may be operating early, or the connnectors to the pcb are not making a clean contact. No specific answer, I’m afraid.
    Stay safe, unplug before handling components.
