Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › AFM 6855 BUILT IN F/F
- This topic has 8 replies, 4 voices, and was last updated 17 years, 9 months ago by
davebaron.
June 20, 2008 at 11:06 am #37522
davebaron
ParticipantHAS ANY ONE GOT ANY INFORMATION ON THESE F/F . THE FAN MOTOR IS NOT WORKING,(SERVIS F/F)
June 20, 2008 at 6:24 pm #255413Penguin45
ParticipantRe: AFM 6855 BUILT IN F/F
Hygena APM6855?
Fan motor to fit -0 version – 512021000
Fan motor to fit -1 version – 512023700Chris.
June 20, 2008 at 7:36 pm #255414davebaron
ITS A SCRIBER I HAVE ALL READY CHANGED THE FAN. STILL NOT WORKING, COULD IT BE SOMETHING TO DO WITH THE MAGNETIC REED SWICHES AND IF SO HOW DO YOU TEST THEM
June 21, 2008 at 7:48 am #255415Dales-Electronic
ModeratorRe: AFM 6855 BUILT IN F/F
Well according to Merloni there is a reed switch available under part number 546037700 but MFI list it as a thermal fuse, located in the right hand side of the freezer compartment behind a cover. To confuse the issue there is a magnet available in the top of the door to activate the door light and (perhaps) the module to feel power to the fan. Let me have a look at the service instructions and if you have an email I’ll push it up the tube.
June 21, 2008 at 3:14 pm #255416davebaron
thank you .davebaron@davebaron.karoo.co.uk
June 25, 2008 at 5:37 pm #255417davebaron
ive now had 3 of these f/f ring now all with the same problems ,fan not working, and the light works intermintantly please can any one send me some info on these please
July 1, 2008 at 6:54 am #255418Dales-Electronic
I have the tech sheet which I will forward to you but the basic points are – the fan switches off when the door is opened. The first time the appliance is connected to the electric it goes into defrost – the fan will not come on until the defrost is finished (usually 25 minutes) and both the compressor and fan can be off for a further 7 minutes ie total 32mins. So if you have just switched it off/unplugged it you can have this delay before it starts up again.
July 1, 2008 at 8:01 am #255419expertcat
Participantif the light works intermittingly then its down to the reed switch for the fridge door.
Check to make sure that the magnet support is screwed down tightly then check the dispaly pcb as this is were the reed switch for the door is housed.
July 1, 2008 at 3:09 pm #255420davebaron
thanks for the help lads ive had another one ring me today , thats 4 in a few weeks ,so any spec sheets or related info would be great
