Aging Siemens – E15 error
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Aging Siemens – E15 error
  • #95363
    APT
    Hi all,
    Sorry, I’ve not got the model number to hand, I’ll try and grab it tonight. The printed sticker has rubbed off but I understand the model and serial should also be etched into the door?
    Anyway, I have a Siemens dishwasher that is about 10 years old and is regularly giving an E15.
    The E15 looks to be a common error with Siemens/Bosch dishwashers of this era, something to do with water getting into the base due to the plastic sides flexing in heat?
    This fits the behaviour we’re seeing actually, in that if we do a short wash, it finishes fine. It’s only if we do a longer or hotter wash that it always seems to throw the error.
    When the E15 error occurs, we just turn it off at the wall, tip it back (a bit of water dibbles out the base) and it’s then fine again (so long as we stick to short washes). Although I understand the E15 can relate to the drainage pipe and filter at the end, these all seem clear for us.
    My question is really, with this sort of error in a 10 year old Siemens, is it worth me opening it up and having a look to see an obvious leak or bad seal in the base? Or is it unlikely to be economically repairable?
    Thanks,
    Andy
    #460144
    APT
    Ahah it’s a SN26M890GB apparently (acording to my post history here)! 🙂
    Thanks,
    Andy
    #460145
    was it just glistening ie condensation or was it actually leaking
    also you don’t have to go to Germany its a gen part
    https://www.siemens-home.bsh-group.c…tlist/12005744
    or
    https://shop.ukwhitegoods.co.uk/miscellaneous-neff-spares-151/12005744-dishwasher-sump-repair-kit
    APT
    Thanks Dave,
    Ahh wow ok, I just presumed it was a clever third party solution.
    I’m pretty sure it was actually leaking from there, the rest of the parts in the base were fairly dry.
    It could be condensation I guess, but for less than £15 I’m happy to take a punt on that kit if it might do the job (and supports UK Whitegoods too). 🙂
    Andy
    #460147
    thrombel
    We’ve got the same error code with our Bosch dishwasher thats 5.5 years old……. E15 just keeps re-appearing & isn’t going away! We’ve had to switch it off at the mains because but the pump kept whirling away, despite turning the dishwasher off on the door front.
    Got Bosch coming out tomorrow to fix it. Hope its repairable……..
    #460148
    APT
    How did you get on with your engineer?
    My kit turned up in the post today so I’ll be giving the repair a go tonight.
    #460149
    thrombel
    The Bosch man identified the problem – the sump is leaking. He’s had to order the part & will fit it next week.
    £29 for a new sump + the standard Bosch call-out fee of £99.
    #460150
    APT
    In the end we decided to call it a day. 9 years seemed like a good innings for ours so in the end we replaced the unit with a Beko (DFN28R22W I think). They seem to have a good reputation on here as being value for money and quite repairable, so fingers crossed. It certainly seems to perform well, its 30min wash does better than our old Siemens quick wash.
