ah error code on whirlpool 6th sense washing machine
Home Forums Public Support Forums Help And Support Washing Machine Help Forum ah error code on whirlpool 6th sense washing machine
  • #84372
    sharon5830
    I have a Whirlpool 6th Sense 10kg washing machine. I have an ah error code along with a loud beeping after 5 minutes of starting a wash and the machine stops. Can anyone help me find out the problem. Thanks
    #425504
    don
    Re: ah error code on whirlpool 6th sense washing machine
    Without a model number it’s hard for the engineers to diagnose 😉
    There is a list of fault codes here which will give you a good start.
    Don
    #425505
    sharon5830
    Model number AWM 1019.
    Thanks for the fault codes, unfortunately Ah is not among them.
    Sharon
    #425506
    johnmac11
    Fault code AH means that the machine has not detected any water coming into the drum in the allocated time.
    Check the water valve is on and that the fill hose is not kinked.
    John
    #425507
    sharon5830
    Thanks for the advice, it has been much appreciated. It was the hot water inlet pipe not working, I’ve replaced it and it now works perfectly so problem solved now.
    Sharon
