AL01 fault code
  • #90414
    DDDave
    We have a Hotpoint Dw SDW80P and the fault code AL01 keeps coming up. We know that this means a leak into the base but we have checked the anti flood, the wiring, the lower spray arm, pressure switch, etc and replaced the module.
    Anybody any ideas as to why the fault won’t go away?
    Rob
    #444699
    DDDave
    Re: AL01 fault code
    Anybody out there any ideas about this?
    #444700
    Martin114
    Re: AL01 fault code
    Hi Rob, this could be the turbidity sensor C00143577
    #444701
    DDDave
    Re: AL01 fault code
    Hi Martin, Spot on. You’re totally correct. Problem solved and machine working fine.
    Thanks for you suggestion.
    Rob
    #444702
    Martin114
    Re: AL01 fault code
    No problem Rob, glad it helped
    Martin.
