all lights flashing!!!!
  • #85091
    redcock49
    Hi i have an indesit that has given up the ghost.
    It started yesterday when all the washing was wet and then would not spin.
    I removed all the pipes at the rear of the machine including the pump and thoroughly cleaned them,i also undid the trap at the front and cleaned this too.i removed the control module and checked all the capacitors and they all seemed fine,put it all back together and then turned on the machine!!
    Any cycle i select refuses to work,however i can hear a click whenever it attempts to go and then all the lights along the top light up and 2 on the side.
    The door still opens when you turn the machine off too!
    Any advice wold be greatly appreciated up till then this has been the best machine we have ever had!!
    #427697
    Re: all lights flashing!!!!
    Moved to correct forum. 😉
    You must have had some shockers in the past then. :rolls:
    The error codes are given by the lower five vertical lights on the right, ignore the flashing lights. Lights number from BOTTOM to TOP, lowest light being 1.
    Not at home ATM , visiting family so only have my iPad. All the error codes are listed at the to
    of the forum, will try and locate if you can’t find it.
    #427698
    Lights 1,2 & 4 is supposed to be F11, drain pump cannot be activated. Check for pump blockages by removing and cleaning the pump filter. Shine a torch inside to make sure there is no obstruction.
    If all clear the the pump wiring or even the main pcb could be faulty. I have seen pumps burn out on these and take out the main pcb. 🙁
    #427699
    redcock49
    if its burnt out would there be visible signs??
    Is it worth getting another PCB and just giving it a go??
    regards
    #427700
    Have you looked at the pump filter yet?
    If the pump has burnt out then it usually has obvious signs of burning on the pump windings.
    A new pcb will cost around £100, it will need programming with a one use only smart card at £20 but to use the card you will need a card reader, around £100+.
    One of the many reasons that the trade does not share your affection for Indesit appliances. 😉
    #427701
    redcock49
    just stripped down the pump and removed all waste,intake and filler pipes cleaned refitted and it fills up,turns and then the dreaded flashing lights~!!
    I know the pump works i can see and hear it but it does not drain it seems!!
    HHHEELLLPPPP
    #427702
    Check all the hoses including under the sink for blockages
