Allen key screws – tamper proof ?
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Allen key screws – tamper proof ?
  • #50782
    nomadPaul
    Hi lads , been to a Technik microwave where some of the casing screws seem to be 2.5mm allen headed screws that have a raised ‘pip’ in the centre. I’ve been reliably informed that they’re classed as tamper proof but does anyone know where i might find the correct bit to remove these screws ?
    Regards
    Paul
    #305970
    maltheviking
    Re: Allen key screws – tamper proof ?
    I got a set from Connect try them
    #305971
    RocketMan
    Try,
    http://www.ukwhitegoods.co.uk/modules.p … ality+torx
    .. this one might help..
    Steve
    #305972
    nomadPaul
    Cheers lads…once i found out what they were called i found a draper set on screwfix for a fiver. I know they’re not going to be top quality but i’ll probably only use them the once….and i can claim the money back anyway.
    Stupid bloody things……….its the only appliance that i’ve ever seen them on.
    #305973
    Seen them on Zanussi washers. 😉
    #305974
    Since Allen keys fit torx would torx (with hole) not fit Allen sockets?
    As for Zanussi washers, had a bearing job on an AEG the other day and everything’s going fine till I find the 6mm Allen socket countersunk pulley bolt 👿 . Hadn’t gone prepared for that. Punched it loose in the end though.
    Mike.
    #305975
    chezza
    cpc had a draper set recently, reduced 😆
    quite a few different tamper proof variants in it too . and lots of microwaves have them these days
