I have the above oven, white version. The grill decided to not function, so i ordered new element and switch and changed both but still nothing. I have tracked it to the thermal cut out fuse, situated behind the grill. The original part is a white wire with a red section, where the inline fuse is situated. I ordered the new part and its been updated with a different part, hence the long wire has been replaced by a small component. Beko are not being as helpful as last time with some advice on fitting, even though they suggested where i can buy the part myself.
I want to check before i go ahead that to fit the new component which has 2 spade connectors that it is simply a matter of cutting the wire either side of the old inline fuse, fixing 2 spade connectors and running the new component in line.
would be very grateful of any advice from people in the know
many thanks
