Alternative for aeg 5212bu main oven stat
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts Alternative for aeg 5212bu main oven stat
  • #86906
    gandh1
    Main oven stat has failed so burns everything, customer loves this built under double oven as it has a fan in the top oven and also the lower oven too so want to try and fix it as a like for like no longer exists!
    main oven stat (dst3110939000) is obsolete, cant find one anywhere online. spec is apparently:
    352 DEGREE EGO 55.13073.030
    [imghttps://res.cloudinary.com/dtk4ybaqk/image/private/t_wm_connections_480/prod/awhgryuxe5epqkr27tod.jpg][/img]
    Can anyone suggest an alternative, even if the orientation is different, I can manipulate the fitting bracket to make it work
    #433366
    gandh1
    Re: Alternative for aeg 5212bu main oven stat
    found 3890770286 which is for the later models. ego code 55.17064.050, any ideas if this would be suitable?
    #433367
    don
    Hi Gandh1
    Long time no speak 😀
    Found this link who are saying they have it in stock. May be worth ringing them to check though.
    Don
    #433368
    gandh1
    cheers don Ill give them a try, I came across several sites (apart from ES) supposedly having stock and not one of them actually had, even though a couple were advertised clearly as “in stock” and “low stock”. I did find a catering company listing the part which seemed hopeful as obv’s it could have been used in commercial kit too, but they dont hold stock, merely source it, presumably from EGO at a daft price!
