Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › AMANA AC2224GEKB
- This topic has 12 replies, 6 voices, and was last updated 14 years, 2 months ago by
johnnyj.
January 12, 2012 at 8:05 pm #67343
johnnyj
ParticipantCan anybody help with this one looked at it for a freind, he says it defrosted and later on it started working again only to stop orking again i called today and it was back working okay again, i’ve given it a quick check but cannot see anything obvious, i was thinging the control board maybe suspect can anybody help please cheers Jj
January 12, 2012 at 9:14 pm #367122sorted
ParticipantRe: AMANA AC2224GEKB
Sounds like another compressor fault get you friend to listen for the BuZZ on start up then clicks of.Poss the control board(jazz board)comp starts with fridge door open then cuts out when door is closed.Remove the bottom plinth about half way along the base of the machine theres a plastic bag in which all the test instructions are hidden. Most likely to be the compressor though cutting in and out.
January 14, 2012 at 7:59 am #367123johnnyj
Thanks went back yesterday and it had stopped then was back working again, i had asked him if he had heard any buzzing like sounds followed by a click, he hadnt but is his wife was there this time she had, so i’m going to have a pop at fitting a new starter for the compressor, the other thing i thought it might be was the condensor fan faulty causing it to overheat and the compressor to trip out
January 19, 2012 at 6:12 pm #367124johnnyj
Went back today and was advised it stopped freezing altogether i plugged it in and the comprressor and condensor fan come on for about 5 secs then goes off i tried another starter it did the same, i tested the compressor windigs i think they are okay ie approx 13ohms, 27ohms and 40 ohms across both windigs, not sure if it is the pcb or a siezed compressor, anybody got any ideas what to try next. JJ
January 19, 2012 at 7:48 pm #367125eastlmark
ModeratorRe: AMANA AC2224GEKB
if it were a faulty compressor or starter, the condenser fan would still run. I do have a wiring diagram if that helps?
January 19, 2012 at 9:20 pm #367126johnnyj
I’ve sent my email address a wiring diagram would be helpful, , i thought the condensor fan should still run but want sure how they were controled. jj
January 20, 2012 at 8:45 am #367127Cras
I had a similar fault on an amana at the beginning of December ,this was cutting out and defrosting every few days and then starting up again .At the time of my visit the fr/frz was running ok so i changed the board and this cured the fault no further fault reported ,hope this helps Cras
January 20, 2012 at 8:17 pm #367128johnnyj
Cheers Cras, thats the thing doing a repair for a friend you try and keep the the price down as they think you owe them a favour, not the other way round.
January 21, 2012 at 8:18 am #367129ELDAR59
hi johnny, the condenser fan should run with the compressor. if they’re both not working or working erratically then the pcb is your problem.
January 24, 2012 at 7:53 pm #367130johnnyj
Went back today with a pcb but i couldnt get it to take the code i dont know if it is a duff pcb or i may have got a pcb for the american market which requires a lower voltage, which wont allow me to programe it. its doing my head in this one, JJ
January 24, 2012 at 8:05 pm #367131johnsdad
Enter code 05, it should be fine
January 24, 2012 at 8:26 pm #367132johnnyj
The instructions advised to use the code on the rating plate which was 28, will 05 allow it to be programed, JJ
January 25, 2012 at 6:22 pm #367133johnnyj
Johnsdad your a hero that was realy starting to piss me off.
