AMANA AC2228HEKB
  • #81307
    don1407
    I’ve fitted a main pcb to this machine and get PE0 000 on display. The ice and water work curing fault but compressor and fan do nor run. I think you need to configure board with code on rating plate. This is 4 digit and not 2 digit like most I’ve done, also the normal procedure for configuring does not work.
    Can anyone please let me know how to configure this board as I have contacted both Whirlpool and Maytag with no success.
    Thanks in advance
    Ian
    #416160
    johnnyj
    Re: AMANA AC2228HEKB
    I had a similar problem a couple of years ago i was advised to use code05 by Johnsdad on my one and it worked hope this helps JJ
    #416161
    don1407
    Thank for reply Johnnyj I have had same issue with the Jazz boards in fridge section. This model has main board at back and a a display board on freezer door dispenser. I just need the procedure to enter code.
    #416162
    burns
    Hi drop me an email to remind me tomorrow and I’ll send you the info.
