Customer asked me to change filter on an Amana fridge/freezer the other day after I had repaired her tumble dryer.. no problem madam!
Problem is I changed the filter but it will not dispense water, water filter light flashing. It will not change mode from crushed ice neither so when you select water it stays on ice and that is not dispensing very well because the flap does not open properly and ice gets stuck in door. Not sure if it is simple re set procedure after fitting filter or if their is a error message being displayed?? any help much appreciated. Model AS2626GEKB serial no: 1000240iet.
Oscar
