Re: Amana fridge freezer – HELP
Hi Nicola,
For a fridge to suddenly start to leak after 6 years is, at best, unusual. It’s possible, but there’s generally always a reason, like it was moved and a bit of pipework was damaged or suchlike. In most cases I would expect to see some physical damage.
The short answer is that it will be able to be repaired, finding a repairer prepared to take it on however is a whole other ballgame as spares are only available from Bradshaws, who aren’t what you’d call cheap and, as you’ve found, not exactly helpful either. 😕
That said, if you’ve paid the chap to repair it, have him back and, if it was one recommended as an agent for Bradshaws you can have a pop at them as well.
Hope that helps.
