amana SRD522S
  • #21061
    PINKY
    afternoon chaps, i have a fault on this. when i went on weds the fan in the freezer was not running and the evap was frozen up. fan tests ok and once i had defrosted the evap the fan started running again. went back today and the fan is no longer running and the evap is froxen up again as a result of this.
    Does any one know what brings the fan on, i assume it should start up as per the stat or H4 device?
    cheers
    #189343
    cab
    Re: amana SRD522S
    Hi not heard of this make before, but most fans run while the compressor runs. If the evporator is frozen it isnt defrosting!
    It might have a mechanical defrost timer on the back which might be sticking, defrost element/stats open circuit. or if its electronic control it might be that.
    cliff
    #189344
    burns
    Re: amana SRD522S
    cab,
    Have you much experience of the Amana, I am looking for a service agent to cover Sheffield / Chesterfield area any interest.
    If so please email your details and anything describing your background.
    Steve Burns
    Maytag UK
    Stephenj.burns@ntlworld.com
    #189345
    lokring
    Re: amana SRD522S
    mmmm!!
    sounds interesting…….. 😀 😀
    #189346
    burns
    Re: amana SRD522S
    We have a local engineer who cant keep up with the work, any ideas :rolls:
    #189347
    PINKY
    Re: amana SRD522S
    cab, you’ve never heard of Amana before? I was after someone with some knowledge of these products.
    #189348
    cab
    Re: amana SRD522S
    hi a fridge is a fridge! 😕 If the evaporator is frozen it isnt defrosting!
    cliff
    #189349
    Re: amana SRD522S
    hi
    the fan is operated by a defrost klixon with orange and grey wires if i remember right and also there is also a thermal overload with 2 blue wires that operat the defrost heater section,by defrosting the evaperator then you are basicly by passing the fault,the unit has a mechanical defrost timer normally at the bottom left or centre of the appliance behind the plinght or in the fridge section top right,
    you can turn this manually to force a defrost and test the nessasery parts.
    bryan
