Ambiano (Aldi) Mini Oven & Hob Element
Home Forums Public Support Forums Spare Parts Help Ambiano (Aldi) Mini Oven & Hob Element
  • #92408
    chrisamyphillip
    Does anybody know where I can buy an element for the oven?
    Model number stamped on element is G25T 115V/230W
    Length is 395mm (thereabouts) including connection tags.
    I’d say approximately 8mm diameter (wide)
    #451165
    don
    Re: Ambiano (Aldi) Mini Oven & Hob Element
    It’s a budget import from somewhere probably from China with no spares available. If it goes faulty under the guarantee Aldi would simply replace if they have stock or refund if not.
    After this period if it fails it simply becomes a disposable item.
    Don
    #451166
    chrisamyphillip
    Hi Don,
    Yes, i appreciate where it’s made etc but as the element is quite a fundamental, presumably common component, I thought somebody here might be able to ‘match it up’.
    Thanks again
    Chris
    #451167
    don
    Hi Chris
    If you want to have a go then you will need to remove the element and then Google the details ie diameter and wattage compare the fixings on the pictures.
    Ebay and Amazon stock quite a few so they could be an option.
    Don’t forget to remove the plug before going in 😯
    Don
