American Fridge Freezer Broken Down
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum American Fridge Freezer Broken Down
  • #19257
    Ozzy1
    Hi there
    I am in Australia and have been unlucky enough to have aquired one of these Fridges with a similar problem to that described previously.
    The exact details are :
    Every 30 minutes or so, a relay at the rear of the fridge starts clicking for about 30 seconds. This happens only when the Ice Maker is switched on.
    When the Compresor fan is running AND the Ice maker is on, the water dispenser “pulses” instead of delivering water smoothly and continously.
    After trying the Capacitor changes mentioned earlier, I still have these problems. I have tried to speak with Whirlpool here but they will not help me They just push me onto a service agent who wants to charge an arm and a leg for what should be a warranty job in my opinion. As a qualified technician I find it very frustrating that I can not get any assistance from the manufacturer about this problem which appears to be a design fault.
    I am interested in anyone else out there who has similar problems or who may be able to assist with identifying the problem. I suspect that it has to do with the power supply on the Rear PCB. Any Ideas out there ?
    #182411
    Re: American Fridge Freezer Broken Down
    Hi Ozzy,
    Going to bump this into the Fridge forum; some of the fridge chaps will be able to advise.
    Find the model number when you get a mo, ta.
    Ozzy1
    Make & Model is Whirlpool S26W3DF but as I understand it, the electronics used is the same as the S25 and S20 series sold in your area.
    Date of manufacture is 11/2004
    It has the same PCB layout as described by other members.
    4 x White MKP Capacitors, 3 Black Relays, 1 Red etc.
    #182413
    Anyone got any info for our Australian friend?
    gegsy
    The front and rear boards are not all the same (only by looks re rear boards) nor interchangeable. Could be a fuffy this one, sorry.
    Ozzy1
    Thanks for your reply
    Maybe its because I am Australian and dont understand your language
    What is a “fuffy” please?
    Also, on a different note, it is interesting that I apear to have exactly the same symptoms as several people described in a previous Whirlpool Thread in this forum. This would indicate that the electronics must be similar if they exhibit the same faults ?
    #182416
    Dave_Conway
    If you can find the service number starting 85???? from inside the fridge (normally) that may help ozzy1.
    I don’t know what fuffy means either 😆
    #182417
    gegsy
    Oh fuff off you pair 😆
    I meant a tuffy 😳
    Ozzy1
    As Quoted from “TheFreeDictionary”
    Fuff´y
    a. 1. Light; puffy.
    It really is a proper word !
    #182419
    Ozzy1
    Lucky I am clever enough to fix this by myself
    I wonder if anyone else figured it out ?
