Going to look at Whirlpool 3RLER5437JQO drier with no heat.
Havent worked on one before, what normally fails? Where do i look for the dodgy part? Any hidden stats etc?
This one has a panel below the door that hinges down. If you look in the gap between the door and the bottom panel you will see a couple of inches in from each side a metal clip, stick a thin bladed screwdriver above each clip and bend down to open the panel.
