Amica AWC10L, no display, won’t reset
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Amica AWC10L, no display, won’t reset
  • #55590
    Seamy
    Got one of these (Amica AWC10L) with power to main board on right, but no go. No burning or obvious component damage. Do these boards give bother & are both p.c.bs to be changed, side & front or will side & or front p.c.b be the likely culprit. Connections to both boards look fine with no corrosion or burnt connections. Ta in advance.
    #324426
    ELDAR59
    Re: Amica AWC10L, no display, won’t reset
    hi seamy, how did you get on with this one?
    cheers.
    #324427
    ELDAR59
    seamy?
    #324428
    I have had this exact fault on a couple of AW23’s, the Amica based ISE machine. Although there is only one PCB in those it was the cause of the problem.
    Might be worth sending Seamy a PM Alf, I have had a couple of e-mail notifications of new posts going astray recently.
    ELDAR59
    well hello cap’n jim! thanks for the tip.
    holiday ok?
    #324430
    Forgotton about it already…. 😥
    Was excellent really, over 80° most of the time. 8)
    Sailor Jim.
    #324431
    Seamy
    Side board sorted it.
    #324432
    ELDAR59
    sailor jim?
    sorry, i’d promoted you mate!!
    #324433
    I think its ten cruises for a Captain, only done five but working on it. 8)
