Got problems with above machine. Runs through the cycle OK. Then, at the program end, the following lights are lit, 40 degrees, 30 degrees, end, and standby light is flashing. At this point, the door is reluctant to open, but customer says she can open it after a while if she thumps the front of the machine. I suspect the interlock, but would appreaciate ane input. Thanks.
