Amica AWCT10l
  • #62317
    thankevans
    Hi been out To amica washing machine under warranty D1 D2 D3 lights showing, Changed motor still all lights showing, Changed PCB still all lights showing.
    Anyone else had this had to lend customer a washing machine.
    any help please
    #349666
    Re: Amica AWCT10l
    only time i had this error code was bad connection to pcb took connectors off put them back all ok
    its got to be a wiring error check all cables to motor fron pcb. check first with plus off and check again with plug on pcb but not on motor
    check you can read tacho from pcb with plugs on and spin motor to see pulses coming up
    hope this helps
    thankevans
    Re: Amica AWCT10l
    Thanks i will give that a try cheers
    #349668
    thankevans
    Re: Amica AWCT10l
    Found a wire on the motor jack broken thanks for the advice got it all running and the bearings have gone.
    #349669
    Applianceman2010
    Re: Amica AWCT10l
    Lol classic! 😉
