amica awct10l
  • #65044
    gomez
    Hi can anyone help with the following fault we have with amica washer.machine will start on any programme you choose but after only a few minutes the machine stops and then the rinse light and spin light show orange and the start pause light shows red and power light goes off any thoughts would be appreciated thanks
    #358995
    Re: amica awct10l
    It’s an error code indicating that there is a problem with the motor which could be a loose wire, the motor, a PCB or anything in between.
    HTH
    gomez
    Re: amica awct10l
    many thanks will check
