Amica Awct10l Washing Machine
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Amica Awct10l Washing Machine
  • #67893
    boesartig
    Hello
    My Daughter Has the above washing machine model which has started to leak water from the filter access point the pump does appear to be spinning freely and not jammed in anyway there are no fault codes is this just a simple task of replacing the drain pump to fix this problem
    many thanks
    #368886
    Steven
    Re: Amica Awct10l Washing Machine
    Is it a lot?
    The filter may just needs tightening up!
    Remove it first give the seal a clean refit.
    If it is still leaking it may be the thin small grey hose.
    http://shop.ukwhitegoods.co.uk/Washing+ … +Hose.html
    HTH
    Steven
