Hi, I`m no great expert on these contraptions!
Machine often when set on a quick wash programme fills and pumps out but not at the same time, i.e. one after the other. Door is locked, motor turns,valves are ok=solenoid coils not burnt out.
I replaced the pcb which cured the problem. Trouble is I now discover that there are 2 boards.Bloody typical!! so not sure I fitted the right one.
These are all the numbers off the machine: AWP510L. SERIAL NO:11400160046401. IPX4. EN-60456. INDEX 1140016.
PCB I fitted was part number 1018692.All the connections are the same, in the same place as each other. Looks as though the other one is 1022237. Any idea based on the info I`ve given which is the correct one please, or indeed does it matter and in what way are these two different. Noticed that on the 30 deg quick was if an extra rinse is selected I still got only one rinse! Or does it mean you always get one rinse it is just a higher rinse i.e. just more h2o.
