amp rating for built in double oven
Home Forums Public Support Forums Help And Support Cooker And Oven Forum amp rating for built in double oven
  • #10617
    we are currently looking at replacing our gas cooker with a double electric oven, and gas hob. We have a point for an electric cooker, which is protected by a 30A circuit braker.
    Will this be sufficient for a modern double oven?
    Cheers
    Simon.
    #141146
    Dave_Conway
    Re: amp rating for built in double oven
    Generally yes, but you’d need to confirm with the manufacturers installation instructions on the specific model to be sure.
    You should be able to get this info from their respective websites 😉
    Hope that helps.
    #141147
    in your case the 30a supply is more than adequate as you are fitting a gas hob
    if you turned both oven and grill i would expect your unit would draw 4 to 5 kilowatts max which works out at 21 amps max
    hope this helps
    Thanks guys. Now, any suggestions on a good oven fro aorund £450/500?
    Simon.
