Ancient AEG lavamat 561 timer knob
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts Ancient AEG lavamat 561 timer knob
  • #10170
    Simon46
    Has any body still got a brown timer knob for e-nr 605634447 f-nr 010679574. every time it is pulled out it comes off the timer shaft.
    Regards
    S.
    #138715
    Re: Ancient AEG lavamat 561 timer knob
    Should be available still under Part No : 899645146970 or you could simply switch the thermostat knob for the timer knob (as they are both the same knob, but you don’t pull the t/stat knob out 😉 )
    #138716
    Simon46
    Dave can you get me one.
    Regards
    Simon.
    #138717
    Thanks 😀
    #138718
    Simon46
    Yes thank you for info martin. Unfortunately my supplier said it came up obsolete, so had to glue knob on shaft as customers are too old to see how it goes in.
    Regards
    S.
    #138719
    Simon46 wrote:Yes thank you for info martin.
    No worries mate, you didn’t try the ‘knob switching’ trick then?
    #138720
    Dave_Conway
    Simon46 wrote:Dave can you get me one
    Yes, if it breaks again let me know, the part number changes, still available from Distriparts at about a tenner though 😯
