anyone have an old one of these kicking about,
its the one with the edge connectors that pushes onto the side of the timer,
ancient hotpoint washer dryer it still has the transit bracket on top of the drum.
Re: ancient hotpoint speed contorl module 904/2735/01
Only just got in from Old Trafford, a bit dark in the garage just now will have a look ASAP.
What is the model number of the machine?
What is wrong with the one you have, apart from the solder contacts breaking away under that connector plug these gave very few problems. A bit of work with the soldering iron on the underside of the plug usually sorted them.
Just had a root around and I have found one for you.
PM me your address and I will get it to you. It was in a box with about 20 other modules some much older that will sadly be going to the tip in the next couple of months when I finally hang up my screwdriver. 🙁
