annoying leak on zanussi 1200
Home Forums Public Support Forums Help And Support Washing Machine Help Forum annoying leak on zanussi 1200
  • #20900
    Transit-van-man
    Ive got a zanussi 1200 jetstream with a leak, its a very small constant water leak and i cant tell where its coming from 😡
    when i remove the lid i cant see any thing all the pipes/connections look fine, ive also turned it on its side and still cant see anything, it’s not coming from the front of the filter either – yet every morning its sat in a puddle 🙁
    Is there any common leaks on this model ❓ which might point me in the right direction 😀
    any help appreciated, thanks 😀
    #188736
    whitevanman
    Re: annoying leak on zanussi 1200
    Transit-van-man wrote:Hi,
    is the machine left running over night ???
    #188737
    white van man helping transit van man, i like it 😆
    would need your full model number to assist but some older jetsytems have a rear mounted circulation pump that is prone to leaking.
    #188738
    Check the fill hoses – very often these weep down the inside of the casing – difficult one to spot.
    Model number would help……….. 😀
    (Big Blue Van).
    #188739
    whitevanman
    eastlmark wrote:white van man helping transit van man, i like it 😆
    😳 :rotfl:
    #188740
    whitevanman
    common sense !!!!
    its not outside is it and its rained overnight ?
    Is the mains water tap behind it/ is is dripping only at night though?
    IS the machine water valve letting in water due to low water pressure?
    Is the filter screwed in properly?
    Is the floor level and are you sure the water puddle is not comming from somewhere else ?
    Has the hose from tub to filter housing got a small hole in it, like its been pricked by a bra wire or something ??
    Has the drain hose got a small hole in it ??
    or as eastlemark says is the rear circ pump leaking ??? or as P45 says is the water leaking down the inside of the machine??
    101 Suggestions U C, Sometime the dog has got 2 c the rabbit
    JOE OR PRO YOU SEE ??
    #188741
    Transit-van-man
    Thanks for the replies guys 😀
    the model number is an FJ.1296
    and no its not left running all night, it seems to leak all the time 🙁
    ive just checked the fill hoses and there not weeping on the casing -shame would have been nice if it was that 😆
    it leaks all day/all night, i appreciate the dog, rabbit etc. im just looking for a few pointers 😀
    Cheers!
    and if either of you white or blue are transit drivers check out my forum http://www.fordtransit.org and i might be able to return the favour 😀
