I, like many other have trolled through this site hoping to find a solution to a problem to no avail, so here goes…
My diplomat 8322 stopped working properly yesterday after someone opened it before it had finished its cycle and then proceeded to press buttons which by the looks of things has confused the program and it can’t finish its cycle…hmmm
What i’m getting is continuous bleeping with no pause and continuing flashing lights with no pause also the program light stays on the 1st setting rince/spray…..the motor makes a noise for a short while then stops but the bleeping continues….there is no blockage or water remaining in the machine!!…any help would be most appreciated
Also I have tried to reset with the top buttons by turning on and pressing start button a few times which takes it all back again only for the bleeping to start once i’ve put a new program on…..
many thanks in advance
00
Since I have noticed 4 flashes after turning on/off…I’ll look for that code unless someone can point me in the right direction?…Ta! 🙂
