Another dishwasher up the creek… but
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Another dishwasher up the creek… but
  • #39314
    Dusty321
    I’m pretty sure it was the inlet valve (overfilling) So I pinched a cold water inlet from an old washing machine and plumbed it in. But alas the valve isn’t opening, so its either goosed or I’ve got the wires for the juice wrong 😯
    Before I go messing again, do these water inlets have a generic power hookup for example they are all + on the left peg and – on the right……
    Cheers
    #262010
    Re: Another dishwasher up the creek… but
    It doesn’t matter which way round you connect a fill valve solenoid, you should test the solenoid with a meggar or multimeter to determine if it is OK.
    #262011
    Dusty321
    iadom wrote:It doesn’t matter which way round you connect a fill valve solenoid, you should test the solenoid with a meggar or multimeter to determine if it is OK.
    So if I tried the power wires in reverse on the solenoid it wouldn’t go bang right?
    #262012
    Correct, but if its not working now then swapping them over will make no difference at all.
    The only way to be certain is to test the circuit to and from the valve and the valve itself with suitable test equipment, with the mains plug out at all times.
    Dusty321
    Cheers Jim!
