Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Another Indesit WD12 problem…
- This topic has 9 replies, 3 voices, and was last updated 20 years, 9 months ago by
admin.
July 6, 2005 at 1:59 pm #10555
KeymasterSorry to bring this machine up again 😀
The machine ( less than 2 years old ) fills then drains and the timer rotates on any wash programme.
Resetting doesn’t help nor does resetting + drain as mentioned in a previous post.
There are 10 flashes on the light above the switch.
I know I’m probably going to end up getting an engineer out but I’d like to have some idea of what’s wrong – could it be the PCB , Eprom or ideally something simpler ?
Cheers in advance
KenJuly 6, 2005 at 2:11 pm #140598Martin
ParticipantRe: Another Indesit WD12 problem…
The fault relates to a ‘water level control problem’, so it likely does need an engineer to call by and check that out. Shouldn’t be too costly for a local guy to get sorted for you. Try our list of approved repairers here:-Repairs@
July 16, 2005 at 10:25 pm #140599admin
KeymasterRe: Another Indesit WD12 problem…
I have 9 flashes and cant get the machine to work.
Checked that little sump thing and nothing. Apart from a little fluff very clear.Any ideas on what 9 flashes mean?
thanks,
Mark.
July 16, 2005 at 10:51 pm #140600Dave_Conway
F9 or 9 flashes indicates an electronic error normally.
If the filter is clear and you’ve done the normal checks it’s probably engineer time to be honest, have a look at repairs@ for one near you 😀
July 16, 2005 at 10:55 pm #140601admin
Thanks Dave. I have checked your engineers but none in my area.
Its just nice to know its not some thing silly.
I did call the number on the machine earlier and they quoted £90 to come out and that my parts are under 5year warrenty.
Didn’t know about that to be honest.
July 16, 2005 at 11:24 pm #140602Dave_Conway
Postcode please (the first part), I’ll check a list I have here 😉
July 17, 2005 at 8:56 am #140603admin
My postcode is ME9
Nice one cheers Dave.
July 18, 2005 at 4:18 pm #140604admin
try
J&J parkinson 02083036950 or sellens Service 01732 521500
July 18, 2005 at 6:29 pm #140605admin
Masher, not sure how I posted in your name, but the above is my post 😳
KevinJuly 20, 2005 at 4:00 pm #140606admin
Just an update guys. Thanks for the posts anyway but all repaired now.
The repair man came out and was here for about 10mins.
It was the memory board! Had forgotten all its programs.
Repair man whipped in a new repair board.
Still had the £90 call out to pay.
