Another Zanussi. ZWF1431S
  • #43540
    DDDave
    Hi Guys.
    I have the above machine that wont start. The display board works, when I press start it beeps,but wont start. I have replaced the interlock but no luck. Any ideas please ?
    Cheers
    Re: Another Zanussi. ZWF1431S
    Go into ‘diagnostics mode’ to check last error reported. If you need info on how to do that then pm me your email address. (Remind me of model number when you do though) 😉
    #277614
    sparepart
    take the board out and check it closely , I’ve got a Zwf1430w that i’m doin at mo , and I had to look closely with a magnifying glass to find it , there are two boards available on exxy at mo , part numbers 97391451756014 and 973914601126001 £15 each brand new , sadly not what I want …….but I suspect fault is board ……Regards Alan
    #277615
    DDDave
    Martin wrote:Go into ‘diagnostics mode’ to check last error reported. If you need info on how to do that then pm me your email address. (Remind me of model number when you do though) 😉
    Thank you. PM sent
    #277616
    DDDave
    sparepart wrote:take the board out and check it closely , I’ve got a Zwf1430w that i’m doin at mo , and I had to look closely with a magnifying glass to find it , there are two boards available on exxy at mo , part numbers 97391451756014 and 973914601126001 £15 each brand new , sadly not what I want …….but I suspect fault is board ……Regards Alan
    Thanks , I did that but could not find any faults.
    #277617
    DDDave wrote:Thank you. PM sent
    But no PM received. 😕
    #277618
    DDDave
    Martin wrote:
    DDDave wrote:
    Thank you. PM sent
    Tried again
    #277619
    Check your email Dave. 😀
    #277620
    DDDave
    Martin wrote:Check your email Dave. 😀
    Email received.
    Thanks very much Martin, I will test it tomorrow.
