Any ideas? Candy cfmf236a fridge too cold, freezer ok!
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Any ideas? Candy cfmf236a fridge too cold, freezer ok!
  • #48068
    washerdoctor
    Just enquiring if anybody can confirm my suspicions that the temperature probe could be at fault rather than the PCB? I have found a probe advertised which is a ff61619 for about £8
    Freezer apparently ok, fridge is too cold (veg freezing)
    I understand that fitting one of these probes involves digging out insulation! Is this straightforward or a nightmare?
    Thank you in advance for anybody who can help! I confess to being more laundry and dishwasher engineer than fridge/freezer but this is a favour for somebody!
    #295446
    Dansta
    Re: Any ideas? Candy cfmf236a fridge too cold, freezer ok!
    Is it a “frost free” and does the freezer cool the fridge section via a fan? Sorry dont see many candy so dont recognise mod.Dan
    #295447
    spanner51
    If it runs non stop
    and the fast freeze neon doesn’t work
    and the interior lamp doesn’t work
    Then its probably the PCB
    #295448
    washerdoctor
    Hi Dansta and thanks for your reply.
    It does not say it is frost free but it is apparently as I’ve looked the model up.
    It is not a cold-air type fridge it is a wet wall type.
    There is only a single dial control at the top which is via a pcb and thermistors, so I am assuming it could just be the probe. Obviously it could be the pcb misreading but I said I would try a probe as a first attempt to fix, particularly as it is cheaper than a pcb.
    I originally thought it was a straightforward mechanical Danfoss type stat but only when I looked it up did I find out it was a potentiometer and pcb/probe arrangement.
    I don’t normally get involved with refrigeration as it is always hassle, but I am doing this as a favour for a friend as a non-expert-but-know-a-bit type of person 😀
    Give me a washing machine any day!
    #295449
    washerdoctor
    Cheers spanner.
    Well, the only fault s I know is that the fridge is too cold. Compressor does cut in and out as normal but funny you should mention the fast freeze neon as I am told that this has been coming on.
    It was off when I looked at it but it has been coming on.
    So maybe a pcb then?
    #295450
    spanner51
    If it’s been going on fast freeze by it’s self, it does sound like a PCB fault
    #295451
    robbo1973
    turn the stat knob to off generally if it is pcb fault the machine will continue to run even though it is in the off position.
    cheers chris
