Any suggestions for replacing a washing machine waste trap?
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Any suggestions for replacing a washing machine waste trap?
  • #53565
    Malane
    I used a Self Cutting Waste Outlet Kit when I first installed my washing machine and I would like to replace it as it is difficult to clean (clogs and slows down the washing machine due to increased drainage times) and reassemble.
    I would welcome any suggestions, including an easier to maintain version of the type I have. Thanks 🙂
    #316457
    gandh1
    Re: Any suggestions for replacing a washing machine waste tr
    im imagining you have a horizontal waste with the “cut in” part located vertically. if this is the case, it shouldnt be too much work to put a standpipe in that will have increase flow. but a picture of your current setup would be really useful to make a proper and correct suggestion
    #316458
    Malane
    Your guess is correct but the pipe is under the sink and there’s not a lot of height to play with. I have taken some photos but I’m not sure how to add them on this forum.
    But it’s not the pipework itself that is causing the problem with flow but the trap – it gets clogged very quickly as I live in an extremely hard water area and the limescale combined with the normal fibres and hairs means a regular clean out is needed. I was wondering if there was an easy to dismantle waste trap available or if I’m stuck dismantling & reassembling this one every few months. Thanks for your help.
    #316459
    Malane wrote: I have taken some photos but I’m not sure how to add them on this forum.
    You will need to upload them to an image hosting site such as Photobucket, Putfile, Imageshack or similar then paste the url of the image into your post.
    #316460
    Malane
    Photos as requested – hopefully!!
    Well here goes: 1)
    #316461
    Malane
    Seemed to work 🙂
    1) is an up-close of the trap.
    2) is a slightly panned out shot:
    #316462
    Malane
    And finally an up-close of the trap itself…
    3)
    #316463
    Malane
    Any suggestions for a new trap type would be appreciated as this one must be fully dismantled, cleaned, taped and reassembled regularly to remain fully functional. Thanks again for all your help, hopefully these pictures are clear enough.
    #316464
    Those DIY things should never be used for washing machines, they may just about work for a dishwasher but cause endless trouble on washers as you have found.
    Either a call to a reputable plumber to do the job correctly or remove the filter part of that contraption and make sure your hose is routed well above the lowest level of the sink.
    The self plumbing taps are just as bad. :rolls:
