Any tips for doing a bearing change on a Bosch WVD24520/04
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Any tips for doing a bearing change on a Bosch WVD24520/04
  • #63049
    trusted
    Has anyone done a bearing change on a Bosch WVD24520/04?
    Any tips/tricks and pointers would be very useful.
    Alan.
    #352326
    Re: Any tips for doing a bearing change on a Bosch WVD24520/
    You really should check out the eSpares website on “How to change bearings” which demonstrates exactly what you ask as it happens. Twas a recent thread on here in fact very recently, though as I’m on a canal boat somewhere in deepest Lancs right now, I can’t give you the direct url link. 😉
      #352327
      Bosch eshop is down for maintenance till 29th. Looks like it may have the “iron cross”. Did something like it on a Bosch washer a long time back. Wasn’t too bad but can’t actually remember too much about it. Usual problem of course is unbolting the cross (torx IIRC) and then manouvering it out through the back – don’t recall having to take drum out of cabinet, but not sure.
      Mike.
      #352328
      trusted
      Thanks guys. Hope you had anice bank holiday weekend.
      I found the link at
      http://www.espares.co.uk/advice/washing … -mach.html
      #352329
      nomadPaul
      Trusted , your model is NOTHING like that one !! For a start its a washer dryer and will have a metal outer tub and an external bearing cross .
