any tips on fitting zanussi w/dry door seals?
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries any tips on fitting zanussi w/dry door seals?
  • #18197
    deltra
    any good advice for fitting these bl###y seals 😥 theres no room to get fingers in,especially where the spring goes behind the hotair inlet ❓ tried for an hour this afternoon,any help appreciated
    #178091
    bobokines
    Re: any tips on fitting zanussi w/dry door seals?
    http://www.ukwhitegoods.co.uk/modules.p … ight=aargh
    try this link
    Bob
    #178092
    Take the lid off. undo the single screw on top of the heater duct and the one ont the front panel, the ‘hot air inlet’ can be lifted up and out of the way. fit the seal as above then re fit the air intake. and the jetsystem hose if fitted. not easy but not that tricky either.
    #178093
    deltra
    thanks guys :tup:
    #178094
    funkyboogy
    no easy answer to problem apart from charging extra for the hassle.
    i take door off, pull appliance forward and then tip back> this gives you much needed working access,once seal on>>use mole grips to secure retainer spring.
    idea fold seal back at bottom >offer spring to bottom of seal then clamp with moles. thus allowing you two free hands to work spring into position..
    cheers ally.
