Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Anyone got any Tech on this?
- This topic has 6 replies, 3 voices, and was last updated 14 years, 11 months ago by
Allsorts.
May 13, 2011 at 6:56 pm #62798
Allsorts
ParticipantHow about this for an oldy… Came in today as a posible refurb. Havn’t tested it yet so no idea if it works or not yet.
Has anyone got any info on this… My guess is about 1950’s – 1960s.
George
May 13, 2011 at 7:30 pm #351355iadom
ModeratorRe: Anyone got any Tech on this?
No tech info George,
What type of gearbox/motor set up has it got. Is it the gearbox with the rotor and stator connected directly to the gearbox or has it got the huge BTH motor linked to the very large gearbox via two rubber couplings.Is the agitator bakalite or alloy?
If you open the door at the front and feel inside for the drain pump actuating lever what type of lever is it, if it is a round knob/round shaft like an old style gear lever then it is the earlier machine, if the lever is a flat bar its the later one.
Looking at the on/off switch, the Hotpoint decal and the fact that it has no heater, I would say 1950’s at the very latest.
It has definitely had the rubber rollers changed at some time.Jim.
May 13, 2011 at 7:58 pm #351356Allsorts
ParticipantRe: Anyone got any Tech on this?
Will have a look at it tomorrow if I get the chance Jim … 🙂
May 13, 2011 at 9:24 pm #351357iadom
If it is the early type then the drain pump is all metal or alloy.
It will almost certainly be corroded away or badly siezed. In fact some of the earliest Empress machines didn’t even have a drain pump, there was a drain tap just inside the door.The motor will always be worth saving, I’ll bet there are still many hundreds of these old BTH motors in peoples sheds and garages driving all sorts of contraptions. 😀
May 13, 2011 at 9:41 pm #351358colly
Done this job for thirty years now.
Been a long time since I saw an empress .
I remember working on the odd one , did more with the countess model .
I once collected the baby of the family known as the princess (only ever saw one of these).
Ah when machines were worth repairing and worth reconditioning too .
CollyMay 13, 2011 at 9:43 pm #351359colly
Can still smell that unique gearbox oil smell
CollyMay 13, 2011 at 9:58 pm #351360iadom
I used to repair as many Empress, Countess and Princess machines as twin tubs years ago.
The major changes to the safety laws around 1972 killed the wringer machines stone dead, it was just impossible to make the wringer mechanism compatible with the new regulations, that was when interlocks were introduced across all washing machines for the first time.
