Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Anyone know how to get into diag on lux int WD no model yet?
- This topic has 9 replies, 5 voices, and was last updated 15 years, 11 months ago by
Rograbbit.
May 6, 2010 at 3:13 pm #54429
Rograbbit
ParticipantHi everyone. Going to a lux washer dryer tomorrow. (dreading it!)
There seems to be a lot of problems with these reading the forums. Can anyone tell me how to get into diagnostics please? It may give me a head start.May 6, 2010 at 4:50 pm #319585robbo1973
ParticipantRe: Anyone know how to get into diag on lux int WD no model
no chance without pnc so many variants
May 6, 2010 at 5:17 pm #319586Rograbbit
Hi robinsonrobbo. Thanks for reply, customer going to text me numbers later, not sure if you will be online? Cheers. 🙂
May 6, 2010 at 7:00 pm #319587iadom
ModeratorRe: Anyone know how to get into diag on lux int WD no model
Rograbbit wrote: not sure if you will be online?
Someone will be, just give the thread a ‘bump’ if no one answers. 😉
May 6, 2010 at 7:25 pm #319588Rograbbit
Hi. Model number ewx 1440w
pnc is 91460230000
ser no is73300129.
Any advice appreciated.
P.S Can you tell me how to get out of test mode also!May 6, 2010 at 7:53 pm #319589chris211
you access diagnostics by with the machine turned of and holding start/pause button and nearest option button turn selector one position clockwise hold down buttons until the leds begin to flash fault codes are displayed at position ten to clear fault code wilst in diagnostics hold start/pause button and nearest option button again it should then go to E00 to exit diagnostics turn selector knob to off again then on and off again it will be ready to go again after you have fixed fault in machine
May 6, 2010 at 8:25 pm #319590Rograbbit
Thank you very much Chris, especially at this time of night. I think its flashing E40 to the customer, which I believe relates to door lock. Then again need to check earth leakage on everything by the sounds of it!
Thank you.May 6, 2010 at 8:27 pm #319591chris211
your welcome yes especially check the dryer heater very prone to earth leakage
May 11, 2010 at 8:25 am #319592Rograbbit
Just an update folks. Been out to this one went into diagnostics after the help you all gave me.
E41 was displayed. Changed door lock as I had a good second hand one. Still the same. Checked and disconnected dryer heaters. still the same.
Customer then told me she could press on the door and get it to work!
On closer look at door starting to part/distort slightly near the door latch.Took apart and reassembled, worked alot better but not 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}.
Have now ordered inner and outer frame and door catch kit.May 11, 2010 at 2:21 pm #319593loopey
quick fix is bend the aloi door pecker with a pair of grips to wards the door lock done loads of them , or change the pecker , very common fault on these , that and the bleedin dryer elements lol 🙁
hth phil
