Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Anything else I need to check?
- This topic has 6 replies, 4 voices, and was last updated 15 years, 9 months ago by
Drunkencelt.
July 16, 2010 at 6:39 pm #55894
Drunkencelt
ParticipantHi,
I’ve identified a blown part on my dishwasher that I need to replace. I’ve sent the following to the parts dept who should hopefully be able to supply replacements. I presume the filter/supressor is just one of those things that blow from time to time. Is there anything else I should be looking at/replacing that might have been affected at the same time? Nothing else seems to be blown and the machine was working well before the incident.
Thanks a lot.
I am looking for a replacement electrical filter/supressor and the replacement electrical cable inlet fitting it mounts to for the following machine please:
Tecnik TKD 795/2 SE6TIE 1GB
The part numbers etc on the items I have are listed below but I have had no luck matching them:
Filter/Supressor 0.15uF + 2x 27000pF X1Y2 + 1.5MR – Ref. 5600003831
Cable Inlet/mount – Eurelectric 5600041012/02/007/07:06Would appreciate if you can let me know if you can supply them.
July 16, 2010 at 10:04 pm #325497iadom
ModeratorRe: Anything else I need to check?
Blown mains filters are quite common on washing machines and dishwashers, apart from localised damage to the wiring harness there is seldom any other problem.
July 17, 2010 at 8:21 am #325498Drunkencelt
ParticipantRe: Anything else I need to check?
Thanks very much Iadom for the reply. Hopefully I can get the spares now and get it sorted.
Cheers.
July 17, 2010 at 8:35 am #325499nomadPaul
ParticipantJust to let you know that your Technik dishwasher is in fact a Siemens machine . The SE6TIE 1GB
number is the Siemens model number and you could check the BSH appliance care website for the correct part number .November 20, 2010 at 1:36 pm #325500Niendertal
Hey everybody,
where can I buy that kind of parts. My Bosh Dishwasher have the same problem.Product ref.
- Eurelectric – 5600041006 / 03 / 331 / 21:52
5600003831 Lt.6267 (56 018 000 026 D3)November 20, 2010 at 1:51 pm #325501iadom
Given your possible location this is the place you need to look at. 😉
Those numbers don’t look like Bosch ones though. 😕November 20, 2010 at 7:07 pm #325502iadom
Sad to say my Portuguese is not as good as your English Daniel but I think this is the page you need.
http://www.bosch-home.pt/assistência-técnica.html
If you enter your model number in the box on the right you should get the diagrams for your machine.
You need to use the Enr number from the top of the inner door on your dishwasher to order parts, not the numbers on the part itself.
