Anyway yo repair split fridge door seal?
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Anyway yo repair split fridge door seal?
  • #101688
    Hard165
    Hi, I have fridge door with a split door seal is there any way repair the split as iv noticed the door Seal is stuck into the door. Is there any type of glue that can repair the seal??
    #485711
    Not reliably no.
    The only real cure is a new seal.
    Hard165
    Can a split door seal prevent the fridge from cooling? Cause I I have fridge that doesn’t cool and the only thing I can think thst is causing the problem is the damaged door gasket.
    #485713
    No, it can’t, that’s a myth.
    If the unit isn’t cooling it’s not the seal that’s your problem.
