apdw/2
  • #24002
    timdowning
    Whirlpool integrated dishwasher.
    Base flooded.
    Water ingress in circulation motor, motor burnt out.
    Can’t run machine due to motor fault, so before ordering a new motor, was wanting to know if there are any common causes of the base flooding?
    Plus part number for motor.
    Cheers.
    #200185
    mvitorio
    Re: apdw/2
    I would guess the pump motor is an Askoll magnetic type. This has tendency to twist and put a strain on the short concertina outlet hose. This hose splits, and voila, base full of water, shorts out motor terminals. New motor part number 481236158432 is CESET capacitor start type, retails approx £100. Check new motor turns before fitting as I have found poor assembly can jam rotor. Also I have previously found control module blown due to shorting of motor, but after resoldering tracks on module all worked ok.
    Hope this helps
    #200186
    Alanj
    Re: apdw/2
    Hi Tim,
    new motor £72.00 inc vat from Connect or Masterpart.
    Alan
    #200187
    timdowning
    Re: apdw/2
    Thanks for responses.
